Rath's Trailer Build - First Test Pull Done!
Rath
Manitoba, Canada
Rath
Adventures
Hey folks, found this forum while looking at ideas for trailer builds.
I'm doing this trailer as a way to carry my supplies and have them secured at base camp while im out and about. Previously I just used a tent to store things in, but that has been proven an issue with wildlife.
Having a trailer will also allow me more room in the back of my truck for sleeping, as thats where my sleeping platform is.
Here are a few photos of progress so far.
bought a 2k lb axle and swapped the hubs out for some 5x4.5 ones
tossed on my summer 35" tires to make it a roller and check clearances to see what size wheel/tire would be best.
1,250 lb leaf springs mounted to the axle, and using wood to make the layout/design I had in mind, and make changes with this. much cheaper than experimenting with steel.
Thats about where I am at right now. Tire size I plan on running is either a 33x10.5 15 or a 235/85r16. Haven't decided yet!
haven't decided what im going to do for a top on it yet, either doors on the side/back to access storage with a roof basket on the top of the trailer. or a flip up lid on the top. not sure yet. open to suggestions!
Reactions: tundra21
Rath
Manitoba, Canada
Rath
Adventures
yikes, sorry about the giant photos. didnt know this forum doesnt resize. will fix previous post and take note for future postings.
took all my measurements today, slapped on a small piece of leftover as a cross piece, and used my tallest (current) items to see what size my uprights need to be to clear. added another inch to the 1/2" clearance I gave it, so it should be good (also taking into account the floor thickness, I almost forgot to consider this hehe).
kinda gives an idea of height. Wish I had more 2x2's to continue around the perimiter to get a better visual. But, measurements taken, will sit on them for a day or two in case I think of something else then I'll be ordering steel and getting to welding!
Rose
W7FSB
US ARMY Retired
Yikes a wooden frame... you pulling that with a Flintstone car... just given ya heck... interested to see where this goes.
Rath
Manitoba, Canada
Rath
Adventures
sorry if that was confusing, meant I was simply making a mockup with wood. Final build WILL be steel lmao
pulling with my 06 ranger!
Billiebob
earth
Bill
Awesome, I'm a big fan of mocking it up to finalize the dimensions.
Reactions: Rath
Rose
W7FSB
US ARMY Retired
Awesome. Really I do like your concept and wanting to see how this goes.
That was supposed to be a joke. I agree with your decision to use wood over steel for mockup. I do the same quite often.
Rath
Manitoba, Canada
Rath
Adventures
Hopefully will be ordering steel sometime this week. Then i can slowly get to welding it all up.
Due to it being winter it may take a while since my shed is barely big enough to fit it, but I'll make it work!
Ontario California
SMR
KO6BI
We don't really have "winter" here in Cali but, I still cleaned out the garage so I can work when its wet outside. Don't know what I would do if I had to deal with snow.
Reactions: TexasGMG
Rath
Manitoba, Canada
Rath
Adventures
I have no issue working out in the snow and cold, I've swapped leaf springs on my truck in -35 temps haha. More so the raw steel and snow/salt issues and the cold and trying to weld issues that are stopping me :P
Rath
Manitoba, Canada
Rath
Adventures
quick question, am I right in thinking that a 2.5" x 2.5" square tube with a 1/4" wall would allow a 2" hitch to slide in?
Ontario California
SMR
KO6BI
If you don't get an answer, I'll look when I get home. The math says yes but seamed tubing may cause an issue with the ID.
Reactions: 64Trvlr
Rath
Manitoba, Canada
Rath
Adventures
Yeah that's what I was curious about.
Not in any rush to get metal ordered up, would greatly appreciate if you could check and get back to me whenever!
Rose
W7FSB
US ARMY Retired
yes And no... yes it will fit, no it won’t fit well... people usually shim the tubing to make it work
Rath
Manitoba, Canada
Rath
Adventures
what sizing would work best then? or is that gonna be as close as I can get it?
or would using 2x2 tube be best, and then buy a receiver to slide over and weld/bolt on, be better?
Rose
W7FSB
US ARMY Retired
They sell receiver tubing... and it’s called just that... it comes in 20’ sticks, but your metal store should be able to cut it to length.
the next best thing is what you already proposed.
Rath
Manitoba, Canada
Rath
Adventures
I'll look into it. I'll be ordering it through one of my customers who buys metal (they get a much better deal, large quantities and what not) so if they can get that I'll go that route then. Thanks!
