Phone applications which record GPX tracks, which can then be exported?
Alanymarce
Trail Mechanic III
1,392
Colombia
One of the reasons we use a GPS unit is to record GPX files which we download for sharing and future reference.
I've learned that there are now phone applications which record GPX tracks which can be exported, so I’m looking into whether one of these could replace the GPS unit on an upcoming trip on which we need to reduce kit to an absolute minimum. It’s neither practical nor affordable to take our own vehicle, and some of the time we’ll essentially be backpacking, but we’ll rent vehicles for some areas and would like to capture the tracks.
I'd appreciate advice from anyone who is using one of these applications: easy to use? Captures tracks efficiently? Easy to download GPX files? Any other thoughts?
wigsajumper
Maine, USA
Aaron
Wiggin
US Army
I have used GAIA gps App in the past for recording GPXs and it worked fine. Even when backpacking I still carry a separate GPS device for recording tracks. Honestly the space saving is that much and you don't have to worry about the phone sucking down as much battery due recording the gpx
Alanymarce
Trail Mechanic III
1,392
Colombia
Thank you. I have Gaia on the phone - I guess I need to find out how to use it... : )
On space, it's not much, as you say, however we need to get down to no more than 13 Kg for 12 months, so every little helps...
Reactions: ThundahBeagle
sopra4343
uk
jhone
smith
I'd appreciate advice from anyone who is using one of these applications: easy to use Toyota Land Cruiser rental ? Captures tracks efficiently? Easy to download GPX files? Any other thoughts?
Great and informative
lolzhax
Roseville, CA, USA
Eric
Walley
OnX does this also. GPX exports and imports are pretty much the standard for mapping applications.
OnX can also export other file types through their web app but the mobile app will only export GPX.
lolzhax
Roseville, CA, USA
Eric
Walley
gaia. OnX is decent, but falls short when it comes to importing gpx tracks, due to it's filesize limitation.
There's a file size limit? I had no idea. I've imported entire BDR trails without issues and can't imagine anything being longer than the CA BDR trails.
lolzhax
Roseville, CA, USA
Eric
Walley
4MB limit. it's been an issue for me.
What trails or files were you trying to import? GPX files are a text based XML files which are naturally very small... measured in KB, not MB. Maybe the GPX file contained someone's entire library of trails? Or a TON of unnecessary points?
Google Maps has a 5MB limit for example.
This is a GPX file as it appears in a text editor.
JT87
San Diego, CA, USA
Lawrence
gaia allows you to attach a photo (jpg) to a waypoint, which is really nice. most of the filesize is probably from the photos.
lolzhax
Roseville, CA, USA
Eric
Walley
GPX files can't support photos. They're just XML files formatted for GPS systems. In more normal terms, GPX files can only store text.
The process for providing photos would have to link to a website where the photo is stored. So in the file would say something like "<image>URL link to image</image>"
OnX has images also.
