2007 Toyota Fj Cruiser
4.0L, 6speed Manual
193000 Miles (will go up this is my daily)
Located in Phoenix, AZ.
$8,125 O.B.O.
-RESZ Fab Heavy Duty Offset Non-Adjustable rear link set with Poly Bushings
-TRD suspension (Bilstein front monotubes, Bilstein remote reservoir rear monotubes)
-JBA Offroad upper control arms in the front
-21in LED light bar in the front grill
-LED ditch lights
-Rear bumper LEDs as well
-Double Din head unit with Apple CarPlay (Bluetooth as well)
-ARB Skid plates for engine, transmission, and transfer case
-ARB Rock Sliders
-JM1 Jerry Can mount with Smittybilt jerry can basket
-265/70R17 All terrain tires
-Factory Elocker in the rear
-I also have a Pro Comp 3in suspension lift that will come with this (brand new in box)
A/C works great
Parts recently replaced:
Calipers, Pads, and Rotors all four corners
Both Front Wheel bearings
Both front CV shafts
Rear parking brake shoes
Rear wheel seals
Spark Plugs
Air Filter
Front Diff, Transmission, Transfer case, and Rear Diff all had the fluid changed less than 10k miles ago with royal purple fluids.
Engine oil was just changed 1500 miles ago. (I Change the oil every 3500 miles with castrol high mileage and a K&N oil filter)
Full Disclosure:
This Fj is from Michigan so there is a small amount of rust near the rocker (underside).
Let me know if you have any questions or if you want to come take a look at it.
Nik - 7three4-6four5-5two65 (call/text)
Thank you
4.0L, 6speed Manual
$8,125 O.B.O.
-LED ditch lights
-ARB Rock Sliders
A/C works great
Rear wheel seals
Spark Plugs
Air Filter
Full Disclosure:
Thank you
