Ozark Mountains - High Water Mark Trail Run
PicNick
Gonzales, La
So I'm headed up to Arkansas for a long weekend on the High Water Mark Trail on the weekend of the 13th with some buddies. I'll be in my Lifted WK2 Grand Cherokee, one buddy is in his XJ and another is taking is RWD mid-2000s 4Runner. We're tackling the trail coming from the southeast, which from what I understand is the more technical part. I've done a portion of the trail near Jasper before which was no problem, but I'm somewhat concerned with the RWD vehicle making the southern section.
Has anyone here recently ran the trail? I'm trying to figure out pacing and if we should leave his car somewhere while we're on the more difficult sections. I'd hate to do that to him, though.
Also, if anyone wants to meet up on the trail just let me know.
Reactions: eagle_A40
Boostpowered
Protector III
3,749
Wolfe City, TX, USA
Davis
Right now not in the wet spring season it will likely be a low water mark trail, and there are multiple different high watermark trail maps so depends on which your following. I wouldnt expect more than maybe 15 inch of water, up to the hubs at most. Tons of folks have done the various trails and i would consider them tame when dry as most forrest roads are.
Worst case is depending on the 2wd guys lift and tires is spotting him over a few rocks and pulling out of slippery sticky mud on banks.
Honestly id be more worried about fallen trees this time of year. Just be sure to take a axe or chainsaw and any recovery gear you have just in case.
grubworm
Thibodaux, LA, USA
mike
c
I just posted on another thread about this...we just got back from Buffalo River and the Jasper area and the water was said to be high. I hadn't been there before, but we kayaked the Buffalo at Steel Creek and the water was moving pretty good, the ranger said it was higher than normal and the Glory Hole has water going thru it and was told that is rare this time of year. Not sure about crossings, but apparently the water is higher than normal right now.
Reactions: PicNick
PicNick
Gonzales, La
Thanks, I'll load that up into Gaia and save it for reference. We've got a chainsaw and a mess of hand axes, so I'm hoping we will be good to go. His lift is more of a level spacer, so maybe only 2 inches in the front. I'll have to see how his tires are looking when we do pre-trip vehicle checks this weekend. Worse case scenario I hope is that he uses his maxtrax a bunch
sjflemingusa
Rogers, AR, USA
Fleming
I live in NW Arkansas.. we have had plenty of rain this year and plenty recently.. You can view the water levels here Buffalo River Floating Conditions If its raining before you get here the waterflow will rise fairly quickly . It also recedes quickly.. It's been plenty wet. I can't attest for the Trail.. I can relate to the trails around me.. Pretty wet conditions.. I would make sure to have recovery gear if your friend is going to 2 wheel it.
PicNick
Gonzales, La
I just found this KMZ file that you can import into most map software.. it has the route someone has recorded or layed out.. looks pretty fun..
Now that I've actually sat down to look at it, that looks like the same one I was using.
We did vehicle checks over the weekend and some last minute mods (buddy wanted disc brakes instead of drums on his XJ) and we're looking like we're good to go. The low for the weekend is still showing in the 20s, so it may be a bit chilly at camp.
If it weren't for me spilling gas out of a pressure washer into the back of my Grand Cherokee, I'd say we'd be riding in comfort. Installed some Bilstein 5100's on the front of mine and did a tire rotation and the ride is much better. Last ride through these mountains had my teeth rattling out of my head until I aired down from 32 to 24. I'll probably still air down for the majority of the trip, but the less rattling in the cab the better.
sjflemingusa
Rogers, AR, USA
Fleming
Sounds like you're ready to run! Take lots of pics.. Share .. enjoy and stay safe.. The weather this week is going to be wet early and dry late in the week.. so I would def make sure the wet weather gear is packed.. We ran some off road trails this weekend and most were damp and not too slick.. lots of leaves on the trails so they hold moisture and keep things slick .. we didn't air down this weekend but when we do i try to get to 20lbs for trails . seems to help the ride and traction on our leaf slime.
Reactions: PicNick
PicNick
Gonzales, La
For some reason I didn't even think of the leaves on the trail. I was more enthralled with the chance of snow since us Louisiana boys don't see too much of it. But then the weather took a turn and doesn't look like we will see any precipitation of the fluffy variety.
sjflemingusa
Rogers, AR, USA
Fleming
We keep getting out hopes up for some snow.. but like most times in AR.. it's not gonna happen, or not enough to really enjoy. This is why we spend the 13hrs driving to CO! Headed there in a couple weeks .. gonna play in the snow and see if we can still get some 4 wheel action on some trails.. Last year it was so dang cold.. -25 in Steamboat, and barely made single digits in Vail.. I don't need it that cold but the snow was awesome!
PicNick
Gonzales, La
I've got some coworkers headed to CO for the week of Christmas and I'm quite jealous. I've never been, but I've heard that it is beautiful up there. +25F is cold enough, I couldn't imagine -25F lol
sjflemingusa
Rogers, AR, USA
Fleming
This was one very unhappy diesel ... Even with the block warmer it was slow to start and a long time to warm up! We're taking the Jeep this trip.. Gonna see how much fun that wll be!
Reactions: PicNick
PicNick
Gonzales, La
So we didn't get to do the entire trail this trip since we didn't cover enough ground on the first day thanks to my smart self leaving the propane regulator at the house. I probably could have gotten by cooking over the fire, but someone else needed to get better thermals so we ended up running to the Russellville Walmart first thing Friday morning. We didn't get very far before we noticed the 4runner had a flat tire. After patching up the nail hole, we hit the road and ran our errands.
We made it back to the trail a couple hours later and headed to Brock Creek Lake. Took a couple photos and headed down the trail some more before turning around and heading to the White Oak Mountain camp on the map. We lucked up and some previous campers left a TON of firewood behind, just needed to be split. A local came and visited with us and told us the wood was free for us to use, which was great because we were all nervous to use it. He also told us that we turned around just a bit too soon at the lake and missed out on a small waterfall on an offshoot trail.
The trail that the White Oak Mountain Camp is on goes back for quite a long way with some great wheeling. It has probably an 800' elevation drop along it and eventually opens up to a football field sized clearing. The way back up is pretty fun with loose rock, rock steps, and off camber turns near shear drops. We were racing against the sun so I unfortunately didn't get any photos of the trail there.
There was a small river crossing that wasn't any more than knee deep at the time, but the rocks were super slick. No drama, no hidden holes, but we strapped the snatch strap to the back of the 4runner just in case.
The third day we covered quite a bit more ground and we able to stop and check out a little foot trail just outside of Long Pool Falls. The trail entrance is on the west side of the road and looks like just a little parking area for a scenic overlook. We skipped some stones in the river while stretching our legs and hit the road shortly after.
We drove a bit north and ended up finding a campsite on Indian Creek Road (1808) just north of 93691I and called it a night. Mainly because it was night when we got there. Now THAT was a rough night of camping. Got down to the mid 20s with super high humidity. Spent more time shivering that taking photos at camp.
The weather took a turn and heavy fog set in on us with a forecast of thunderstorms that night. We decided to take the trail to highway 7 after stopping on McMinn Knob and taking some eerie crew photos.
We called the trip finished a day early and aired up to highway pressure. A good thing too, since a series of really bad thunderstorms hit the next day for what looked to be the entire route home.
Reactions: Offroadnutz
PicNick
Gonzales, La
I can’t get this file to work in Gaia. I’m guessing I’m doing something wrong.
Did you download it to your computer first? You have to go to your account, click upload, then it will give you the option to select to file. It says that it can only do GPX, KML, or FIT, but it works with KMZ as well
CasperZR2
Indiana, USA
Cory
Swanson
I was trying it on an iPad
