US East Ohio - 2004 Discovery II - $15k
Rover 4
Supporter
Southern Florida
Kissell
4″ lift . By 3″ Heavy duty springs and 1″ Coil Spacers suspension kit
1.5″ Wheel Spacers
Cross Member Spacers
Shocks Procomp ES9000
Front Lower Shock Mounts
Rear Spring Retainers Upper and Lower
Front and Rear Vented Disc Brakes (less than 2k)
Brake Lines Stainless Steel
ABS Extension Cables
OLD MAN EMU Steering Stabilizer
Disconnected Front Sway Bar
Adjustable Panhard Rod With Right Heim Joint Chrome Moly
Rear Drive Shaft Convert Rotoflex to a U-Joint
Front High Angle Double Cardon (CV) Drive Shaft and Flange
Transfer Case With Center Differential Lock
TD5 R380 Manual Gear Box
4.6L Engine
Custom Conversion to Manual Transmission was done by Specialist Mechanic
Front And Rear 24 Spline ARB Locker With Heavy Duty Air Line Kit
QT Heavy Duty Engine Mounts
XD 9000 Self Recovery Winch By WARN
ARB Deluxe Bull Bar
HID Lights Installed in High Low And Fog Lights
Two IPF Xtreme Series Fog Lights
Four Light Force 240 Blitz
Safari Expedition Roof Rack
Viair 550 C Air Compressor
Hella Rear Light
Safari Snorkel
Heavy Duty Rear Bumper
Heavy Duty Rock Sliders
Tires 33×12.50xR18LT Cooper APX (2nd set on Hurricane rims with Kuhmo M/T)
4- 3.5Ton Gross Tow Dixon-Bate
2.5″ Exhaust MagnaFlow Mufflers
Dual Optima Batteries (New Red top just replaced)
Alpine CDA-9857 Cd Player
Alpine V-Power 4 Channel Amplifier
email me for photos
Rover 4
Supporter
Southern Florida
Kissell
located in NE Ohio, just south of Canton. sorry for the delay in responses, my notifications were setup (by me) correctly.
Rover 4
Supporter
Southern Florida
Kissell
yes, and in the low 90's. Its been in storage all winter, and i'm just back from FL. i can respond in the morning with Odometer.
Rover 4
Supporter
Southern Florida
Kissell
no over heating, and i know its a common issue. mileage is 93,166. rig has heavy fax setup, and the enhanced thermostat as well.
Rover 4
Supporter
Southern Florida
Kissell
sorry, FAN setup not Fax. i'll be reposting this Discovery with updated photos, cold start. It's been on blocks since December, with battery support and fuel treatment. just a reminder, this is a manual left hand driver, not an automatic. The original goal was to replace the 4.6 Bosch with a diesel from a European spec, but the Bosch hasn't shown any issues to this point.
