Off-Road Trailer Manufacturers Listing
lost again...
Lorain County, OH, USA
None
I was going to put together a list of trailer manufacturers, but when I searched, I found a great resource on The Adventure Portal
http://www.theadventureportal.com/off-road-trailer-buyers-guide-2015-2016/
They have a spreadsheet with several manufacturers listed, with web links, phone numbers, prices, etc. [LINK], but I'm sure this will change frequently. So if you are in the market, look around and see what's available. Please post links to any other sources or manufacturers that aren't listed. No need to list distributors, as that is region specific.
Three that I know of not on the list are
Sylvan Sport Go http://www.sylvansport.com
Taxa's Cricket and Tiger Moth Trailers http://www.taxa.us
Backcountry Box's Roady and Rocky trailers http://www.backcountrybox.com
CDN Offroader
St. Albert, AB, Canada
Adam
Houghtaling
Reactions: MarioT'sCJResto
lost again...
None
Tennessee Trailers, Inc. now makes an Overland trailer. I got the following information from Eric Burger, the VP:
"The overland trailer is 78" wide overall. The box is on the trailer itself is 48" W x 70" L x 24" H approximately. The side rail tubing is exposed inside so it takes up some of that space. The trailer has a 5,200 lb GVWR and over 4,000 lbs of payload. It'll go wherever the tow vehicle can go."
The trailer starts at $4995, and they are in the process of redoing their web site to include these and their kayak trailers. http://www.tntrailers.us
Little Frog Kayak Trailer (Base Price: $1,535):
I'm having them look at something in between; a light enclosed trailer with kayak capabilities.
Reactions: Keith McAlister
Defender 90 Keith
Plymstock, Plymouth, UK
Keith
Pierce
These look good but no doubt shipping to the UK would be expensive. I'll have to keep looking here for a cheaper option.
Reactions: Steve
Anchor Mtn
Fruita, Colorado
Anchor Mountain Overland makes custom overland trailers.
Our standard Overland Utility Trailer (OUT) starts at $4250 and comes with a black powdercoated frame and tub powdercoated in a number of colors. A custom made 65" wide 3500lbs torsion axle, LED lights, aluminum tailgate and 17" wheels with 285/70/17 tires are all standard. The tub is 60" x 48.5" inside with an additional room for gear on the tongue. Each trailer is built to order in Fruita, Colorado.OUT1.jpg
Defender 90 Keith
Keith
Pierce
Our standard Overland Utility Trailer (OUT) starts at $3900 and comes with a black powdercoated frame and tub powdercoated in a number of colors. 3500lbs torsion axles, LED lights, tailgate and 17" aluminum wheels with 255/75/17 tires are all standard. The tub is 60" x 48.5" inside with an additional room for gear on the tongue. Each trailer is built to order in Fruita, Colorado.View attachment 17616
looks good. a nice simple design
AKBushDag
Palmer, Alaska
David
Plant
G
Great Info! Thanks
Reactions: Steve
Tahoe
Fair Oaks, california
I'm thinking a trailer is the way to go if you want to do some 4x4ing while out on the trail. Having to unpack a rig and unmount stuff from the top/back seems like it would be much more trouble.
Is there a good consensus about which is best if you like to do more serious 4x4ing while on a trip?
Reactions: Rubiconcruiser
jdunk
Pathfinder II
4,387
King County, Washington, United States
Josh
Duncan
I would say that it really depends on budget, vehicle, how much comfort you want, and how long you're going to stay out there...
Reactions: Tahoe
Tahoe
I guess my main thing is that I want to be able to do as many different things as possible so I know I have to compromise in the level of each thing.
jdunk
Pathfinder II
4,387
Josh
Duncan
Going with more utility, and less purpose built (slide outs, etc) will probably be the best way if you want flexibility. The next is size. If you're going to use it offroad, I would recommend that you don't go any wider of a wheel base than whatever your pulling it with.
Reactions: AKBushDag
