New member from Nothern, VA.
kz195688
NOVA
Hi, new member from Stafford, VA. Looking forward to meeting other members in the area and also reading about others vehicle preparations and their overland travels. I drive a slightly modified 99 Toyota Land Cruiser. Be safe.
Reactions: Kent R and Chadlyb
Chadlyb
Bend, OR, USA
Hello and welcome to the OB crew....great Toy for your adventure platform and look forward to seeing your build and your adventures.
kz195688
NOVA
Welcome!
Any pics of your Cruiser? :D it a 90 series or a 100?
Sorry, no pics at this time. I'll get some up, eventually. It is a UZJ-100. White with beige interior. I have owned and Eden working on it since the end of 2013. It has 242k and I just did my second timing belt, water pump, tensioner, fan bracket, fan clutch and the other things that are normally done when you are doing the timing belt.
Modifications are: ARB front bumper with 10k winch with synthetic rope; Iron Man front torsion bars with medium rear springs (2 1/2" lift), tough dog front and rear shocks; Firestone rear airbags; Trail Taylor rear heavy duty lower control arms, control arm skid brackets, and extended rear sway bar ends; Slee off-road rear skid plate for rear locker motor; Asfir front aluminum skid plate with TJM oil pan and transmission skid plates; no name snorkel; 285x75x16 GY tires; dual batteries with Slee battery tray and Hellroaring battery isolator; triple locked with factory rear locker, center and ARB front locker.
I also did the version of the "grey wire" mod for the rear locker; day time running light mod, and center "locker" mod. I recently did front and rear brake pads and the previous owner had Toyota install after market drilled and slotted rotors.
I have done most mods and maintenance with the exception of the front install of the ARB locker which OTRAM did (I installed the ARB switches and wiring). I wired cleaned, brushed and POR 15 the frame to resist rust. I do get a lot of information from other sites such as IH8MUD.
Been enjoying the build and will eventually purchase or build a rear bumper.
OB Executive Director
Welcome to Overland Bound!
https://www.overlandbound.com/forums/forums/overland-trip-planning.21/
You are in the East Region, local information can also be found in the “Overlland Bound by Region” section of the forum toward the bottom of the main forum page.
Here is the link to contact your Regional Director.
https://www.overlandbound.com/forums/threads/overland-bound-regions.5928/
Hank Outdoors
Sean Hank
Haney
Welcome to OLB and the East Region!
If you have any questions or want help planning a trip or meetup of your own feel free to message me.
When looking for events near you check the Calendar at:
https://www.overlandbound.com/forums/calendar
Looking for a meetup? Check this link:
Looking for the U.S. East Forum? Check this link:
https://www.overlandbound.com/forums/forums/u-s-east-va-wv-md-de-nj-pa-ny-ct-ri-ma-nh-vt-me.83/
