N-Fab side steps feedback?
boss324
Tracy California
Brian
Castro
Hello all -
I am looking into sliders or something that will give me better protection than my OE running boards. Anyone have or had the N-Fab sidesteps on your rig? How did they hold up off-road? Do they get hung up on the trail? My options are slim on my platform 03 Suburban and N-Fab is one of the only options rest are tubular steps or full-length running boards.
Thanks,
Sent from my SAMSUNG-SM-N920A using OB Talk mobile app
maxfederle89
US
Can't say much on if they function well or how stout they are but they look good. Do you have a welding/fabrication shop near you? If the options are slim a good fab shop could probably build you some hell for stout sliders. They may even be able to powder coat them.
Sent from my SM-J320V using Tapatalk
Reactions: boss324
Daniel Etter
Fishers, IN
Dan
Etter
I have heard a lot of the years that they do get hung up on objects since they are not a flat surface to slide over the obstacles.
Reactions: boss324
boss324
Tracy California
Brian
Castro
That is what I figured. Also looking into N-fab lund rock rails series it appears they are available for Silverado...the search continues. I wouldn't mind swapping out my running boards for the N-Fab as it would be better protection and will get hung up less???
Jaydub514
Southern California
Jason
Rangsipat
The N-Fab side steps are more like rugged looking running boards than actual protection giving rock sliders. Like others have mentioned they could end up causing more damage Off Road if they get hung up and crunched against the rockers!
boss324
Tracy California
Brian
Castro
Thanks all for the feedback will be looking for a local shop to fab some up for me. Unless lund or nfab rock rails workout..
Masheen365
South GA
I have looked into the Lund Rock Rails for my F-150 and all the hands-on experience I found said they wouldn't support weight. They basically just protect the rocker panels from debris getting kicked up on the trail. From what I saw in pictures they DO NOT attach to the frame, instead they connect to the body? I'm not sure, but if I ever need sliders I will find a fab shop to make a stout set.
Reactions: boss324
darthyota
Check out my build thread and see what I'm doing for sliders on my Raptor, the design may work for the Suburban and will for sure work for your F-150
Reactions: boss324
DieselPilot
Georgia and Florida
I had both N-fab steps and N-fab Rkr rails on a GMC Sierra, I don't think they make the Rkr rails for the Suburban. While the Rkr rails were definitely made out of a much heavier and thicker metal they still weren't a true rock rail. Both mounted to the body and not the frame and would cause significant body damage if used for a rock slider.
Only option I ever found was to have someone custom fab me a set.
Reactions: boss324
boss324
Tracy California
Brian
Castro
The search continues...
Sent from my SAMSUNG-SM-N920A using Tapatalk
