Best compact compressor would probly be an ARB though you will definitely pay for it lol. They have a ton of mounting options though like under hood brackets and whatnot. What size tire do you need to fill and how fast do you want it to fill is the real question lolLooking for recs for a portable compressor, the more compact the better. TIA!
I used a Smittybilt for years and it worked great, still have it as a back up. It's a little on the slow side but cheaper than some. I run a 37" tire so I switched to a CO2 tank in the back because I am usually in a hurry for some reason. If I had the option I would go with an ARB under the hood and run lines to each corner of the Jeep. Something I have all the parts for ( minus the compressor) but have never got around to doing loli'm a pretty patient fella
i'm looking to upgrade to a set of toyo open country AT III. if not that, something comparably sized.
I have 2 the first is 20 years old and I have no idea the model, it was about 35 to 45 mins to air up my 35’s from 20# to 60#. I picked up a 400 and now out 20 to 25 mins. To do the same. I do really like them both. The first is in the suv now.Which model are you using?
Thanks for the rec!I have 2 the first is 20 years old and I have no idea the model, it was about 35 to 45 mins to air up my 35’s from 20# to 60#. I picked up a 400 and now out 20 to 25 mins. To do the same. I do really like them both. The first is in the suv now.
I have a Viair 88p. It's quite small and works fast enough for me.Which model are you using?
what's your tire/wheel setup? is that an OB i spy in the photo?I have a Viair 88p. It's quite small and works fast enough for me.
Educator II
That’s the model I have, it works great.I have a Viair 88p. It's quite small and works fast enough for me.
This is the key question. We have two - a small one which we've had for ten years and which takes 20+ minutes to inflate a tyre. and a newer one ( AC-PRO Air 150) which delivers 375 L/min at 150 psig which we bought to air up more quickly. Needless to say we've used the small one a few times and the new one not at all, so far....What size tire do you need to fill and how fast do you want it to fill is the real question lol
I wonder if anyone has bought two cheaper units to speed things up - if speed is an issue. Even two of the cheaper units can be las than one of the more expensive units - plus you then have some redundancy.There are alot of small compressors that will work. You dont necessarily have to buy a name brand or expensive one. You can use a hand or foot pump if your feeling athletic.
Good thought! Never occurred to me.I wonder if anyone has bought two cheaper units to speed things up - if speed is an issue. Even two of the cheaper units can be las than one of the more expensive units - plus you then have some redundancy.
Theres actually a YouTube video by dirt lifestyle where he has started to build a dual smittybilt setup for his roverI wonder if anyone has bought two cheaper units to speed things up - if speed is an issue. Even two of the cheaper units can be las than one of the more expensive units - plus you then have some redundancy.
