Found a spot to mount the shovel & axe. Would you do it differently??
Sent from my SAMSUNG-SM-G891A using OB Talk mobile app
I thought about that, I need to redo my fenders and change over to a 5 lug axle. Did you build your trailer?That will work. I mounted mine to the top of the fenders. Ron
I was thinking about that. I was also looking at the Dexter axle with the five lug from Tractor Supply as well. I think that would be a simple swap and with the rating weight it would be more than enough. More research before I make a decision. Thank youYes, I built mine from scratch. If your axle capacity is enough, you can change hubs instead of the whole axle. Good luck, Ron
Hey RC would it be possible to do a trailer walk around? Your trailer looks like something I might want to build. What are the dimensions? ThanksI was thinking about that. I was also looking at the Dexter axle with the five lug from Tractor Supply as well. I think that would be a simple swap and with the rating weight it would be more than enough. More research before I make a decision. Thank you
Yes, I will do a walk around this weekendHey RC would it be possible to do a trailer walk around? Your trailer looks like something I might want to build. What are the dimensions? Thanks
Sent from my SM-G955U using OB Talk mobile app
Lol, thanksYour trailer is awesome, however sir your wall paper is epic. Budweiser and pepsi for the win
I didn't actually get around to shooting a walk around video yet. My trailer is a Coleman Columbia tent trailer frame. I resized and reinforced the frame and flipped the axle. The top is 5 sheets of plywood to make the 4x8 box. The bottom and walls are 3/4" while the top is 1/2 inch. Basically it's a box on wheels lol. I went to the salvage yard and picked up two matching windows and a cargo door. The cargo door was the hard part in trying to find the right size uhh. The bottom I coated with Flexx Gard from Tractor Supply and the exterior is coated with Kliz Over Armor Textured. In hind sight, I wish I would have pre filled the screw holes coz I thought the Over Armor would. It did not in some areas. I have 10 coats of Over Armor covering it. The interior, I bought mineral oil and coated all the exposed wood. In total I think I have about 500 to 600 into it. Hope this helps :)Hey RC would it be possible to do a trailer walk around? Your trailer looks like something I might want to build. What are the dimensions? Thanks
Yes it does. Thank you. Qustion, Do you think the 4x8 is to narrow for two adults? And still waiting to see the trailer. Thanks.I didn't actually get around to shooting a walk around video yet. My trailer is a Coleman Columbia tent trailer frame. I resized and reinforced the frame and flipped the axle. The top is 5 sheets of plywood to make the 4x8 box. The bottom and walls are 3/4" while the top is 1/2 inch. Basically it's a box on wheels lol. I went to the salvage yard and picked up two matching windows and a cargo door. The cargo door was the hard part in trying to find the right size uhh. The bottom I coated with Flexx Gard from Tractor Supply and the exterior is coated with Kliz Over Armor Textured. In hind sight, I wish I would have pre filled the screw holes coz I thought the Over Armor would. It did not in some areas. I have 10 coats of Over Armor covering it. The interior, I bought mineral oil and coated all the exposed wood. In total I think I have about 500 to 600 into it. Hope this helps :)
I chose 4x8 because it fits nicely behind the Jeep with no wind resistance and fits the Jeep trails. If your a big guy like me and your partner is small then it's snuggle up time. It all depends on what you want. Either way it's quite comfortable :)Yes it does. Thank you. Qustion, Do you think the 4x8 is to narrow for two adults? And still waiting to see the trailer. Thanks.
