Educator I
- 10,890
- First Name
- Jim
- Last Name
- Bro
- Member #
12989
- Service Branch
- USAF DAV
Educator I
12989
Protector III
20111
Educator I
12989
Thought you were going to say "going to Starbucks". ;)I see many a sky high truck which is good for
Benefactor
0000
Also a good point to plan ahead. A lot of folks build suspension over time. That’s what I did. If you do that, it’s good to know where you are going so you always have a well handling rig. That’s NOT what I did.Thought you were going to say "going to Starbucks". ;)I see many a sky high truck which is good for
Seriously though, great article and it should be pinned at the top of the vehicle build sub-forums. As stated, quite often touching one part of of the suspension/driveline is going to lead to other required modifications which leads to other required modifications and so on. I see a lot of folks slapping giant tires on their vehicles only to find that performance/braking becomes sub-par - a little research would show bigger brakes and a re-gear may also be required (and tougher axle shafts, and...). I really like Ronny Dahl videos and his approach to modifications; he explains the pros and cons, etc.
An interesting piece of wisdom that I picked up on OB went something like - "if you can learn to overcome the obstacles without a lift, without big tires, you will become a better driver and able to conquer more obstacles". When the "pioneers of overlanding" started doing the Rubicon trail they did not have 33 or 35 or 37 or 40 inch tires and lifts yet they made it. Food for thought...
It has only taken me 20 some odd years to purchase my first lift / suspension mods which are still sitting here in boxes. Hahaha. But I researched the heck out of it and went with a Clayton setup that is well thought of in the Jeep community and one of the only kits that takes the added weight of what we do into consideration.Also a good point to plan ahead. A lot of folks build suspension over time. That’s what I did. If you do that, it’s good to know where you are going so you always have a well handling rig. That’s NOT what I did.
Benefactor
0000
I feel ya :)It has only taken me 20 some odd years to purchase my first lift / suspension mods which are still sitting here in boxes. Hahaha. But I researched the heck out of it and went with a Clayton setup that is well thought of in the Jeep community and one of the only kits that takes the added weight of what we do into consideration.Also a good point to plan ahead. A lot of folks build suspension over time. That’s what I did. If you do that, it’s good to know where you are going so you always have a well handling rig. That’s NOT what I did.
They sure do. The Americans have caught up quite a bit over the last 5 or so years but the Aussies are still ahead of us.The Aussies get it.
World Traveler I
30034
right after i bought my tundra, we went to sedona and i went on a pretty simple jeep trail and kept bottoming out. i went home and put on a level kit and went up to the biggest tire that would fit (around a 34" equivalent) and that has been the perfect set up for meExcellent article. The most I'm planning is a leveling kit and calling it good.
World Traveler I
30034
Right there with you. 63 myself. Also not planning on doing anything extreme either. 33's on the truck now with the 20 inch rims. At some point I'll be switching to 17 inch rims and most likely staying with 33's.right after i bought my tundra, we went to sedona and i went on a pretty simple jeep trail and kept bottoming out. i went home and put on a level kit and went up to the biggest tire that would fit (around a 34" equivalent) and that has been the perfect set up for meExcellent article. The most I'm planning is a leveling kit and calling it good.
besides, im getting close to 60...the way i drive, a giant lift is only going to look like i'm "compensating"![]()
Influencer III
19540
I wouldn’t have realized you had done anything after seeing your rig.right after i bought my tundra, we went to sedona and i went on a pretty simple jeep trail and kept bottoming out. i went home and put on a level kit and went up to the biggest tire that would fit (around a 34" equivalent) and that has been the perfect set up for me
