Hot weather camping
Biker Eagle
Chelsea, AL, USA
Culbertson
Former NOPD LEO
For those of us who live in the hot and humid south, hot weather camping is a fact of life.
Here's a couple of ideas to make it a little more comfortable. First, forget the ground tent. Get off the ground and let "convective cooling" work for you. Try hammock camping...it really is cooler.
Second, look at a RoofTop Tent option. It gets you off the ground and elevates you so you can catch those breezes and get away from the days heat being released from the ground.
Third, use an awning to create some shade and refuge from the heat of the sun.
Fourth, use technology like my Ryobi lithium battery powered fan. It could be the difference between a miserable sleepless night and a comfortable nights rest.
If you've got a system for beatin the heat, share it.
peeewhyy
S. Cal
Had the same question I normally try not to camp during June/July depending where in CA. My RTT gets hot if you try to sleep in and have tried the off brand LED 4 D cell fans and they have failed always. I was actually thinking about getting that Ryobi fan... Might have to pick one up this weekend. Planning on taking my son to Majove Road next month so need anything that will help..
VCeXpedition
Torrance, L.A., Cal., Earth
Dan
Rich
K6DHR
Not to second guess you, but seems like Mojave Road in July is a very bad idea IMO. Won't be crowded! Let us know how it goes.
<hijack over>
I will go to HD and buy that battery set and get my free fan! I drank the Ryobi punch a long time ago.
Dan.
peeewhyy
S. Cal
<hijack over>
Dan.
Yea it is still in the air about doing the trail during the week but the heat is what I am worried about......
LVCoffeeguy
Pathfinder II
1,545
North Las Vegas, Nevada
Patrick
Monson
We are in Las Vegas and camp in all types of temperatures - but mostly hot ones..... We actually use that same Ryobi Fan and love it. It is not very loud in the low setting and the high setting is worth the little extra noise when you need that air to get moving. It is also super nice that we can use an extension cord and plug it right into the inverter. We can keep the fan going on low all night and hardly see the draw in our dual battery system. We also have the Awning and a RTT. When ever we can't find good shade we will leave the rainfly to create a little bit of a heat barrier between our tent and the sun. This does seem to help on those hot days at least a little bit.
DividedSky
USA
I like to use my grabber space blanket on top of my tent to reflect the sun. Reflects heat and keeps the tent dark in the morning. Seems to be the same material as the tent posted above and is surely cheaper than any purpose built cover.
LVCoffeeguy
Pathfinder II
1,545
Patrick
Monson
But with that blanket how are you going to look like you should be camping in space like that tent above does?
I might have to give that blanket a try! Do you need to tie it down or just lay it on top?
DividedSky
USA
Depends on the wind situation. They have grommets on all 4 corners, so I usually use a bungee cord to lash it down.
SLPNBG
Mechanicsville, Va
I have a small rechargeable/USB powered fan from amazon. On low it seems to last forever, on high, nah. I have a 30000 mAh battery pack with 3 USB ports for the fan, phone or whatever
old_man
Loveland, Colorado
Tom
Houston
WØNUT Extra
I have a 12v fan for under my awning with my teardrop and run a small mister in the fan. It delivers a nice cool breeze. The teardrop is insulated with 1" of Styrofoam and with the fans inside it is nice even in the heat.
LostInSocal
Chino Hills, CA, US
I dial back the camping during the summer months, but when I do I head for higher elevation. In the forested areas, it's just finding some shaded area for the tent and sleeping with the rain fly off.
I'm planning to try hammock camping this summer though. I've got the ENO OneLink system to experiment with, and if it works out over multiple trips, I may spring for a Warbonnet down the road.
Jim SoG
Forums Manager
Educator I
10,890
Reno, NV, USA
Bro
USAF DAV
Gotta get high! 8000' or more does it.....
