GPS Noob
Apoclapedia
Adventure
Moha, British Columbia, Canada
Matt
Smith
I grew up on a 70’ schooner so navigation was just part of life from a young age. I can navigate oceans and continents with map, chart and compass. Using mainly long and lat for marine navigation and UTM grids for overlanding. I constantly have my nose buried in an BRMB.
As much as i love the little rituals of analogue navigation. It can be time consuming when youre both the navigator and the driver. Not being able to do both at the same time.
Ive avoided gps in the past out of a being ignorant to its fine points of use. The fact that i dont like handing important jobs to gadgets i can fix. And from what i cant tell they seem loaded with gimmicky features i dont need.
That said. I want a GPS. I want to learn the ins and out of their use and get something that fits my needs.
What i would like is something that lets me view satellite images and topo. Something that tracks my routes and allows me to mark points i use as camps and chaches. I prefer UTM grids over gps coordinates so being able so see those to would be nice. Lat and long are just better for marine applications then terrestrial nav.
So im wondering what you guys are running, your experiences with different brands and their pros and cons. And systems that require cell service are out of the question for me because im in British Columbia and cell service isnt a thing here.
Things i dont need are campsite info, points of interest, paddle routes and all that other data i never use.
So, where should i start?
Reactions: BCNP4runner
Downs
Hunt County Texas
Joshua
Downs
KK6RBI / WQYH678
I clung to my purpose built GPS receivers for a long time. I finally made the move to the phone and tablet based navigation (that don't require cell service to work) and never looked back. IMO this is the direction you should look. Multiuse items are far better to me than single use items.
Reactions: Apoclapedia
ptgarcia
Alta Loma, CA
Paul
Garcia
I have several GPS that I use; a chart plotting GPS (Lowrance Baja 540c), a handheld (Garmin GPSMAP 60Cx), and various cell phone apps (Locus Pro, OsmAnd+, Gaia) and I like and use them all. However, the more I play with it the more I like to use Gaia on my iPad. It will do everything on your want list and more. And if you have the hardware the software is cheap when compared to the stand alone units.
Alanymarce
Colombia
My first GPS was a a Garmin unit (1999) - used for capturing GPS points in the Sahara - basically to know where I was and download later to have waypoints for future travel. Still have it, somewhere... and since then have stuck with Garmin because they work, at least for our needs.
We've had a couple of units in the last decade.. We had a Colorado 300 (and still use it while we're at home, since it has the local (national) map loaded, and we use the other one for travel in other countries so don't need to switch maps when we return home). Our second unit is a GPSmap64st; we had T4A loaded for Africa and then Garmin's Australia map for (guess where) - Australia.
They're compact, run on 12V DC in the vehicle, however have batteries if we want to walk a bit and track our route, and give us what we want, which is to know where we are with reference to our surroundings, to be able to download the GPX files (Garmin Connect and BaseCamp) for reference and to share with others. We don't use them for "turn-by-turn" directions - not of interest to us.
They show terrain but for satellite view you need something else. We can (and do) track routes, and can mark waypoints.
I hope this helps.
US Northwest Region Director
Benefactor
La Grande, Oregon, USA
Rose
KJ7MFV
Hold out about a month and OB1 will have exactly what you are looking for.
Apoclapedia
Adventure
Matt
Smith
Im leaning towards a samsung Tab 10 and Back Road Map Books mini sd for British Columbia. Anyone running a Tab 10? I like the idea of a larger screen so i can see it easily while driving. All the GPS units ive looked at have really small screens. Is there a GPS unit with an 8 or 10 inch screen on the market?
BCNP4runner
Los Alamos, New Mexico, USA
Jeff
K
KI5FGO / WRFH471
So far, I like the GaiaGPS app on our phones/tablets. All your maps/routes/waypoints are backed up to the cloud and available on all of the devices attached to the could account. You can pre-sync the routes etc and pre-download route maps for when you're our of cell phone range. My only complaint is that our older devices were GPS only with no GLONASS, but that was easy enough to fix with a DualGPS 160 GPS/GLONASS antenna that can link via bluetooth to all of the phones/tablets. While paper maps have their advantages over gadgets, the gadgets have some strengths too (they don't suck in the wind). The two technologies (paper map & compass vs gps gadgets) complement each other well.
TroutRunner
Traveler II
395
Durango, Colorado
David
KY0TEQ
Matt as others have posted Gaia and a iPad or other tablet work real well together. If you do go this route make sure your device has a built- in gps receiver in it. iPads that have cellular capability have gps built -in. I have used gps’ in the past with search and rescue. By far the best is Garmin that I’ve used. We used topos and gps’ and used UTM as our coordinate system. Worked really well. I still use land-based navigation for my current job to give coordinates for wildfires and helo landings. We use lat/long. I am finding that more and more I just use my iPhone with Gaia to get coordinates for wildfires. Gaia has a free version you could try out. To get the more detail maps and features you will have to subscribe to a plan. Give it a try.
BCNP4runner
Jeff
K
KI5FGO / WRFH471
If your iPad doesn't have built-in GPS, there is a solution: The Dual XGPS160 SkyPro GPS Receiver. It's a GPS/GLONASS antenna that can connect to as many as 5 devices (phones, tablets, etc) via BlueTooth and I've found that it produces much more stable/accurate position information than the internal GPS devices in phones/tablets, particularly in rough terrain (esp canyons). It's small enough to just park on my dash under the windshield. (There's also a less expensive version that that connects to only one device at a time, as well as other competitors, though I haven't tried any of the others.)
Reactions: FishinCrzy
TroutRunner
Traveler II
395
Durango, Colorado
David
KY0TEQ
Garmin makes one as well called the GLO2.
1Louder
Steward I
3,974
AZ
K
K1LDR
Your smartphone, if you own one. Then use an app like Gaia GPS or BackCountry Navigator, or the OB App, or any other mapping app. You don't need to buy a dinosaur dedicated device. Hit YouTube for more details.
Reactions: M Rose
Apoclapedia
Adventure
Matt
Smith
So im in BC and my go to has always been Backroad Map Books. They started in the early 90s producing map books and have been the standby around here for a long time. So i gave them a call to see if they had digital maps. They do but only micro sd for garmin gps. While i do love garmin. I dont want one for overlanding. Because they dont make one with an adult size screen for off road use. So i opted for the BRMP app. You just download the sections you want for offline use and a subscription is $3.50 a month.
Reactions: rgallant
wigsajumper
Maine, USA
Aaron
Wiggin
GAIA GPS has the Canada BRMP as an overlay available also.
LoCo_Ex
San Anselmo, CA
Ben
Easley
Sounds like you need Gaia GPS with the Backroad Mapbooks layer for Canada, or, Backroad Mapbooks has their own app with offline capability. In all honesty, you might want to get both!
the drawback off the BRMB layer in Gaia, is that it doesn't have all of the POIs and other info that you get in the BRMB app (similar to their mapbooks).
