Gnasher, My 03' Land Rover Disco II
Gnasher_PNW
Graham, Washington
Hello, All.
Presented here is my 2003' Discovery II, Gnasher.
I've had Gnasher for about four years now, and have done every bit of work on him myself.
Not entirely sure what all to put in here... Hopefully what I do will cover most of the basics.
Gnasher, before I began putting heavy work in.
(Note: Vehicle didn't come with anything on it. It was a well maintained, but stock vehicle. After much scouring of the internet, I scored the roof rack for $400, and the rear ladder for $50, also the brush guard for $200..)
After the paint job: I did paint the roof.Landy-0014.jpg
After I installed the Tactical4x4 front bumper.
Engine:
4.6L Bosch V8
Build:
I haven't done anything to the motor, and I haven't changed any of the drive train out with heavier components (yet). Differential gearing and T-Box gearing remain the same as stock. Later, I would like to put 30% crawler gears into the T-Box and beef up the differentials.
Otherwise, I've done.
Lucky8 front drive shaft
Snorkel (oh did it hurt cutting out those 70mm holes)
Rock sliders
Terrafirma medium duty lift kit
Voyager racks roof rack
x6 18 watt Cree LED lights
Rear door ladder
Modified tire carrier w/ CB antenna hook up
CB Radio and RAM-X mount for my iPad-mini installed onto front dash.
Re-painted the rig to military #383, Olive Drab.
Hand built limb risers
Hand built Hi-Lift carriers onto the roof rack
Installed axe and shovel mounts onto the roof rack
BF Goodrich TKO2's @ 265-75-16
What I have left:
a.Re-gearing T-Box and differentials
b.Installing FarmTek double-ply poultry kennel flooring onto the roof rack as flooring
c.Building a storage system for the rear cargo hold of the Rover, with a center box designed to handle extra communications devices.
d. Build and install a drawer system for the roof rack, which will hold a 100 watt solar panel, that will be used to supply a Goal Zero 400wh Yeti, for section C.
e. Re-build the lighting system for the roof rack and front bumper
f. install a dual CB antenna system onto the front bumper, for my dash CB
g. Install a winch.
Now, I need to get out onto some adventures!
Thanks for taking a look
~Ryan
ShawnR
Davenport, Iowa
Awesome rig. And you are in a great place for it. Use to visit my ex's family in Spokane. Back then I didn't have a rig suitable for any serious off roading. Hope to go back someday and explore the area along with Northern Idaho and Montana. Anyway, always loved the Discos. Hope to someday have one in the stable.
Reactions: Gnasher_PNW
Gnasher_PNW
Graham, Washington
Thanks, Shawn.
Still more work to do, and modifications to be planned, but when isn't there?
Eastern Washington as beautiful. It is mandatory to have a capable rig out there, especially during the winter months. Anyone daring the Passes otherwise, is a damn fool.
I've never been into Idaho, honestly. I will make my way that direction once I'm back home.
I hope you do get to go back, the PNW is an amazing place.
I also hope you're able to acquire a quality Disco!
mellowdave
Austin, Texas
I have a box of parts, left over from my old Disco that I would ship to you if you are interested. PM me.
Power Steering Pump, Valve Cover Gaskets, Plug Wires, etc.
