- First Name
- Lucas
- Last Name
- Antes
- Member #
7082
- Ham/GMRS Callsign
- KE0ZXA
What general maintenance (not upgrades or add-ons) do you have planned to do or already have done to your rig? With most of us, we have aging rigs that have a good amount of miles, wear and tear, and may not have been kept up with by previous owners. I want to put together a general list of things to keep on the radar over many upgrades. I feel like this is a topic that sort of goes without saying but should be covered more for the sake of having reliability among the capability of our rigs. Let me know what you think should be on the list to be helpful when planning out a build or just taking care of everything. Thanks!
Body/frame - cabin filter, address rust/paint issues, body mounts, motor mounts/bushings, liftgate/glass struts, door/weather seals, glass
Driveline - U-joints, driveshafts, axles, grease fittings, wheel bearings, ball joints
Engine – oil/filter, belts, pulleys , air filter, sensors
Fuel system - injectors/carb, fuel pump, fuel filter(s), lines
Exhaust – gaskets, manifold, muffler, O2 sensors, cat(s)
Cooling system - coolant, water pump, heater core
Steering - steering stabilizer, ball joints, power steering pump, power steering fluid, tie rods
Brakes – lines, fluid, rotors, pads, calipers, drums/shoes
Lighting - bulbs w/ dielectric grease, lenses
Electrical – fuses, battery, battery terminals
Interior -
Suspension – bushings, end links, shocks, springs, control arms, track bar, sway bars
Transmission – fluid, filter(s), gasket
Diffs – gasket, gear oil, gaskets
Transfer case - gear oil, seals
Interior -
