I saw in one of @Lifestyle Overland tutorials, he has Google map as one of his map source in GAIA. Does anyone know how to do this?
Thank you for this^^He learned everything from me.. :)
How to Import Custom Maps into Gaia GPS - 4X Overland Adventures
Updated 12/2020 - Gaia GPS updated the custom map tool. The steps are essentially the same. This quick tutorial will show you how to install custom maps into Gaia GPS. While Gaia offers a wide variety of mapping options you may have some more specific needs. For this example, we show how to...www.4xoverlandadventures.com
You bet. It has worked well for years.Thank you for this^^
I just walked through this and the sources are blury (may still be caching) but the terrain maps come up black... have you experienced that before?He learned everything from me.. :)
I can check my settings later this evening. You might see if some new paths to the files are listed elsewhere.I just walked through this and the sources are blury (may still be caching) but the terrain maps come up black... have you experienced that before?
Thanks! You are the man! Loaded the road and hybrid maps perfectly. Just like what @wvjeeper said, the terrain maps turned up black-- but I think the default Gaia topo is good enough. Again, thank you. Now my Gaia GPS is complete...He learned everything from me.. :)
I tested it as well.Thanks! You are the man! Loaded the road and hybrid maps perfectly. Just like what @wvjeeper said, the terrain maps turned up black-- but I think the default Gaia topo is good enough. Again, thank you. Now my Gaia GPS is complete...
Perfect... again, thank you!I tested it as well.
Try this path instead:
http://mt0.google.com/vt/lyrs=p&hl=en&x={x}&y={y}&z={z}&s=Ga
Thank you for the updated source! I appreciate it.I tested it as well.
