FOR SALE FS - Rock Krawler 3.5" X-Factor JKU Lift
harv3589
Alberta, Canada
Rock Krawler kit for sale, includes the following
(4) Long travel functional multi rate coil springs
(2) Double adjustable track bars made from 1.5" solid alloy steel with Anti-Wobble joints
(4) High clearance adjustable lower control arms made of 1.625" solid alloy steel
(2) High misalignment double adjustable front upper control arms made from 1.25" solid alloy steel
(2) High misalignment double adjustable rear upper control arms made from 1.25" solid alloy steel
(2) Front sway bar disconnects (Teraflex)
(2) Rear extended sway bar links
(1) Rear track bar relocation bracket
(2) Rear coil spring degree wedges
$2000 Canadian
Located in Calgary Alberta
Not included are the brake lines and disconnect straps. Lift is in excellent shape and has only 15,000kms on it.
