I'm thinking about switching my 07 4Runner Factory (Clutch) radiator fan to an electric Flex-A-Lite fan. Would like any feedback on this.
Thank You!Never been a fan of Flexalite.
Whatever fan you choose, just make sure you pay CLOSE attention to CFM's and compare it to what your OEM mechanical one pulls. I found over the years that you have to spend $$$ to get a fan that will pull proper air to cool your engine.
Some cheaper alternatives are Ford Taurus and Windstar fans and I believe there is a Volvo setup that also works well. Google will be your friend. If you don't mind JY hopping, it can be a great money saver.
Thanks for your feed back! This is one of my concerns!!I have a dual flexy fan that the PO had put on. I have had over heating issues since I got it...
Thank you! So far, it looks like an aftermarket fan is not the way to go. I live in Alaska, so overheating is not a real concern. I was hoping to be able to actually keep the fan off when the weather got really cold. The more common practice is to put a "Winter Front" over the radiator which blocks/prevents the fan from pulling air through the radiator, that works but takes more power away from the engine.Don't have any direct experience but went on an overland trip with a tour operator last year and they were very much against aftermarket electric fans. Too many failures and overheating issues apparently. There again I'm talking about headed out into a 48C desert.
I guess that's a very different scenario! Does the extreme cold affect the electrics? For water crossings you can tie off a clutch type fan to stop it spinning but I don't think this would be a good thing to do for any period of time.Thank you! So far, it looks like an aftermarket fan is not the way to go. I live in Alaska, so overheating is not a real concern. I was hoping to be able to actually keep the fan off when the weather got really cold. The more common practice is to put a "Winter Front" over the radiator which blocks/prevents the fan from pulling air through the radiator, that works but takes more power away from the engine.
I've been in about -25 F and no electronic problems so far. Of course, I do have a "Battery Blanket" to keep the battery warm. Currently using the Factory lead/acid battery but will be switching to dual AGM batteries. They will probably still need a Battery Blanket to keep them at max output, but they won't freeze and crack as with a lead/Acid battery.I guess that's a very different scenario! Does the extreme cold affect the electrics? For water crossings you can tie off a clutch type fan to stop it spinning but I don't think this would be a good thing to do for any period of time.
Thanks for the tip on water crossings! :-)
