Do you really need lockers for Overlanding?
Toyotadirtdevil
Carmichael, California
Nantz
I'm trying to make a decision on whether I really need lockers for Overlanding.
I recently went on a trip with @O.Dfj and he had a locker in his fj and I have nothing in my 2 Gen Toyota. I went every where he went.
I know I need to change my gears but it's a struggle to afford both.
What's your thoughts?
Reactions: O.Dfj
Wawa Skittletits
Local Expert East Region USA
Expedition Master I
5,079
Wilkes-Barre, PA, USA
Drew
Hawley
WRBZ674
USN veteran
I think it's definitely a nice thing to have but certainly not necessary. If the situation were to arrise they would keep you going compared to not having them. As a result only slowing you down because of a winch/pull moment. Admittedly there are situations where having them would be safer but now we're getting into knowing your rig and recognizing the danger. Don't forget that there are people who overland in 2wd vehicles and that you can always add later or just do the rear now. If you're getting where you need to go without issue now, you have the luxury of time.
The other Sean
Minneapolis
A locker will allow you to go slower over obstacles which is easier on your vehicle and the environment. Needed? not always. Helpful? yes.
With that said, If I was spending money regearing, I would make all attempts to add a locker(s). But, on the flip side, adding lockers will add $$$ to the install.
With that said, I would put lockers over many other items a person could add to their vehicle.
RaggedViking
Readsboro, VT
I have a locking tush on my 4Runner and I've never used it - I haven't had to - but it's a nice feature to have because you just never know what kind of mess you'll get into.
I was out on my property in Vermont last year and there was a considerable amount of snow on the ground. I ended up getting out into this bowl where the snow was about 8-10" deeper and I thought I was done for.
I considered locking my rear - as a last resort - but never ended up needing it.
O.Dfj
Influencer III
3,689
Foothill Farms
You dont need a locker but it makes it easier.
Reactions: RaggedViking
Wolfy
Reno
I don't think so. I haven't used mine in the course of overloading. Only rock crawling, and I don't do much of that. I think the advantage you have with wheelbase on your truck will get you over most obstacles. I've seen those Toyotas do a whole hell of a lot with open diffs. If you want to do 4x4 stuff, then yes. It's absolutely necessary for real 4 wheeling. But for overloading, at least my definition of it, you can get by with a strap and a dude in a green FJ. (that sounds kinda kinky doesn't it.)
-M
ChepoCDT
Mexico City
Chepo
CDT
I think it depends where you are offroading... For me, in the center of Mexico, there is a lot of rockcrawling and I need them (actually bought them yesterday)... I have been in many places that it would have been easier to get out if I had them.
If you go out by yourself I would highly recommend to have at least rear locker, why? because sometimes your own equipment is not enough, or you don't have a place to hook yourself and get out with a winch and having traction with all the wheels is going to help a lot!
That's my opinion, everyone will talk depending their own experiences...
Reactions: Mad Garden Gnome
Njtraveler
Hackensack, NJ
In my experience it has more to do with the terrain. Articulation, inclination, and mud/snow seem to drive my use of the lockers. But if I didn't have a two speed transfer case I'd focus on the gears above the lockers. Although doing ether is a great opportunity for the other.
Being able to drive in a controlled manner (think road speed and rpm/torque) makes it much easier to not have lockers. Recovery equipment should be first. It will help you learn and overcome "deficiencies" in your rig. Cause let's face it, A cum a long, hi lift jack, and some chain/ strap can get nearly anything around with time.
Reactions: Toyotadirtdevil
Rank IX
Benefactor
15,584
Murguia
KM6YSL
Ya, what others have said. Totally depends on what you are going to do. Simple answer is no. Given that many overland in 2wd cars and stay on highways, that's not needed. I love my lockers, but do not engage them often. I don't need to. I'd get a winch before lockers which is a generally versatile tool that will get you out of most situations, its just more cumbersome.
My .02
Mad Garden Gnome
Templeton, Ca
Ryan
Marlett
W6ORV
^^^This
Mad Garden Gnome
Templeton, Ca
Ryan
Marlett
W6ORV
^^^ This too
Mad Garden Gnome
Templeton, Ca
Ryan
Marlett
W6ORV
No one neeeeeeeds a locker (from the guy who is locked fore and aft).
  1. If you are okay with getting over/through obstacles by shear force / power / hammering it, you don't need a locker.
  2. If you rarely encounter terrain in point 1, by choice or chance, you don't need a locker.
  3. If you are well equipped with recovery gear and comfortable with it, you don't need a locker.
Or
  1. If you are the individual that is the constant source of loiter time in the group due to having to 'hammer it' 8 times to get past one obstacle, you are encountering terrain regularly enough to consider getting a locker.
  2. If it constantly takes you more than one try to get past obstacles on the sort of terrain you prefer (think Tread Lightly here) consider getting a locker.
  3. If you are re gearing due to tire size, this is admitting you are going after the more advanced stuff, consider a locker.........as financially painful as that sounds. Save up the money. Do both at the same time (rear locker and both axles). Those larger tires are going to be a longer lever to hold the side with traction which exacerbates an open differential situation.
Tread Lightly.
At the end of the day I like to turn to my wife and cackle like a maniac in proclaiming that we didn't even Spin A Tire Once.
Njtraveler
Hackensack, NJ
Or
Tread Lightly.
My wife and I had the exact conversation. But I think the awesomeness of the comment was lost on her. Lol. Bad enough she is slowly realizing her daily driver is becoming my weekend warrior.
Reactions: mmnorthdirections
Mad Garden Gnome
Templeton, Ca
Ryan
Marlett
W6ORV
The first step is admitting you have a problem..........
:laughing:
1Louder
AZ
K
K1LDR
I added 33" tires to my FJ. I would like to re-gear it. I won't be adding a locker to the front. What Toyota provides is good enough for me. Your mileage may vary. I'm 3 years into off-roading and Overlanding with this vehicle of that means anything.
Mad Garden Gnome
Templeton, Ca
Ryan
Marlett
W6ORV
Do you have traction control? The traction control that is coming on newer vehicles seams to be very capable.
Reactions: VDawg1115
aearles
USA
Agree with what's been said by everyone here.
I'd only add that I am a terrible planner and always end up in rougher situations than I expected. Even if you're only planning to "overland", it often ends up turning into wheelin' instead of turning around.
I'm locked front and rear. It's pretty great watching the guy in front of you spin and squawk up an obstacle and then just rolling through it without any drama. I'm not super experienced, the truck just makes things easy.
maktruk
95046
Had to sit behind a 4Runner at Hollister Hills last week while they tried about 6 different lines, all in vain, at a simple rock garden. Spraying small rocks and chunks of rubber everywhere. On their sixth attempt they got out and started stacking rocks. (They probably wouldn't have had to were it not for shitty tires at street pressure)
Me and my buddy, already locked, nonchalantly rolled past them and proceeded up the garden barely turning a rock over. Thru my sliding rear window I heard "look, all their tires are flat!"
Lockers rule the trails and save equipment.
shoredreamer
Santa Cruz
RRU
KM6AZV
Guess it depends on your definition of Overlanding, which in turn is rooted in what you do and what you want to be able to do with your vehicle. In many ways, you are what you drive. And sometimes your rig determines how you choose to travel. A la, if you have lockers, you seek out challenging terrain.
My 80 was born with lockers so it never was a choice or a decision but I've used them a ton of times either out of necessity or to help ease my heavy pig over rocks, thru snow drifts or up some steep loose hill. It's one more tool for preparedness. I've used my lockers many many more times than I have my winch.
