DIY Limb Risers on JKU
Cappy410
Okotoks, AB
Stephane
Fortin
Some often ask me "what is the purpose of those wires from your hood to your roof rack?" We "overlanders" know, but it makes for a great conversation and the response is always "Cool! You do that stuff?" I want to share how I added limd risers to my JKU.
First I'll do the roof rack. Everything but the rubber pipe clamps was purchased at Home Depot. The pipe clamps I purchased from one of my local plumbing wholesaler $2.50 cdn each. 1-1/4" to 1-1/2". I didn't want to drill holes in the rack, so I found this solution one day doing a counter day at one of my wholesalers. The rubber is a great sound isolator too! The nut on the clamp is 3/8" so I had to buy 3/8" eye bolts. They are 2-1/2" long so I had to cut it down but left enough thread to put a second nut to tighten it from spinning.
Reactions: justin marsh
Cappy410
Okotoks, AB
Stephane
Fortin
Now for the hood latch part. I didn't want to put holes in my hood either so I came up with an idea to use the hood latches as my tie down points. You'll need to remove the latches (really easy to do) and add a 3" - 2hole straight bracket. Now, you will need a washer for the bottom bolt to make up the thickness of the bracket. JKU owners will understand once they pop the hood and see what I mean. I used lock biners for easy removal for the windshield replacement guys. They really appreciate that feature. I think in total, I spent $25 cdn to do this add-on.
eric.ryan.davis
Nice write up! By far the biggest question I get too is "What are those string things for?" lol
UKCRD
LOL. Often get that question, too. I think some assume they're mini clothes lines. :blush: Good write up!
E
expeditionnorth
Guest
I've been wanting some, but fear they might whistle at highway speeds?
Cappy410
Okotoks, AB
Stephane
Fortin
Bahahaha! I had someone in the parking lot come over and ask me what the risers were. My response "they're body limb deflectors so that when the zombie apocalypse comes I can drive thru the dead and the limbs will deflect away from my windshield". His face...priceless, I wish I took a picture. @administrator
Rexor91
Kaiserslautern, Germany
Have any pictures of your setup?
Sent from my SM-G930V using OB Talk mobile app
