I new to overloading and looking to build a f250, what are some of the pros and cons of that 6.7 for overloading
Ford Pro's:
Dana 60 front axle. Ready for a locker. Putting a Yukon Grizzley locker in mine.
Rear axle stock with Elocker. And it's actually decent.
6.7 is fine. Run it hard and clean the EGR.
Good transmission
17-18's with plow kits are nearly lifted and leveled.
35x12.5r18 +18mm offset fits stock truck.
super easy to install quality suspension systems
all aluminum
free spin hubs stock
Fox ats steering damper available
Ford cons:
XL, XLT, STX are best. Upper trim models have 1st world problems. Avoid moon roof, avoid adaptive steering.
19+ models are lowed 2" from the tall 17's
no manual trans
manual xfer case gone in 19+
death wobble
poor quality technicians that can't diagnose something as easy as death wobble
poor quality shocks. Get Bilstein, Fox, or King 2.5's.
Rhino line the bed asap.
Recommend going 350 if you decide to go diesel. Diesels are heavy. And a diesel 250 might only have a measely 2000# cargo capacity. Check your cargo capacity sticker before buying anything. Gas 250 is better for campers, if you have to stay 250 for some reason.
Make sure you need the diesel. 6.7 won't suffer fools that use it as a grocery getter. But the 6.2 will.
