Disclaimer- Please read this carefully! (Moved 3/1 to a more visible location)
*Please allow 3-5 business days for delivery*
*Please note these are an aftermarket product, that are intended for off-road use*
*They are to be installed at the owners discretion, and the owner will assume all risk*
*The builder is not responsible for any damage to any vehicles during the installation or use of these products*
*It's the buyers responsibility for securing any loose parts when the links are removed*
*No used links will be returned*
*1 year warranty on all links (cost after 1st year)
*All sales are final*
*By purchasing these links, you understand and assume all risk*
These links will work on lifts up to 3", and add an additional 1" to the overall length. These are made with 1/2-20 LH chromoly rod ends with nylon races. They have 3/4" hex bar that has been drill to 1/2-20 LH on one end and 1/2-20 RH on the other. The bushing side has 1/2-20 B7 threaded rod that is rated at 150,000 PSI. All links will the option of red or black Energy Suspension bushings. These will fit stock sway bar link mounts, and no drilling is required for these. You can get these made two different ways.
I'd like to give some information on the double disconnects and getting them disconnect. First off, please do not over tighten the top bushings. Over tightening the top bushings will cause you to not be able to release the top pin. If you wrench down on the bushings, you will not be able to slide the heim off the stud.
3rd Gen 4runner Links:
4th & 5th Gen 4runner, FJ Cruiser, and GX Links:
Custom Powder Coat Links:
These are my 3rd Gen double-disconnects.
PLEASE READ BELOW FOR PRICING, AND KNOW WHAT YOU'RE ORDERING WHEN YOU ORDER IT!
Pricing
*Standard Links - $170 for front or rear; $220 for front and rear
*3rd Gen Disco's - $200 for front; $250 for front and standard rear
*4th and 5th Gen Disco's - $220 for front; $270 for front and standard rear
*Powder Coated - +$20
*Heim Boots - +$20
Thanks,
Pricing
*Heim Boots - +$20
Thanks,
