Compressor Recommendation for under $100?
805RADO
Santa Ynez, CA, USA
Lost
Sasquatch
There are so many portable compressors out there, and until I have real money to buy a proper one, Im looking for something under $100. Any suggestions? I will not be using it a lot but the few times I do, I want it to at least work.
Winterpeg
CDN Prairie Ambassador
Winnipeg, MB
You get what you pay for... sounds like you know that though.
Just grab one that you can afford... a $50 one should work for a bit. I melted mine down but it lasted a few months (almost a year), then I got an ARB one.
Good luck.
805RADO
Santa Ynez, CA, USA
Lost
Sasquatch
Good luck.
ya I want an ARB one but have other larger projects on the list first! ha
Reactions: Winterpeg
vegasjeepguy
Gravette, AR, USA
I guess it depends on what you're going to use it for. If airing down "big tires" and then using it to air back up, you'll be hard pressed to find a sub-$100 compressor that won't take all day and suffer failure due to overheating. I bit the bullet and bought a Viair 440P 10 years ago and it's still going strong. It's had so much use I had to replace the rubber gasket in the chuck due to wearing it out. As with everything, especially with gear, you really do get what you pay for.
The other Sean
Minneapolis
I've got 285/75/16's and have never been the last person to air back up with my MF-1050, so, YMMV...
Reactions: kickkem
805RADO
Santa Ynez, CA, USA
Lost
Sasquatch
Good to know. I might have to go with the viair 400p or something close to that. more than $100 but sounds like it can do the job. (ill use it maybe once a month)
000
No
I saw someone use one of the harbor freight ones a couple days ago and it seemed to get the job done. Probably won't last long but if it's for very occasional use, it's good enough for now. I had a Costco compressor that worked ok for $50 the name started with a Q? Spending a little more for a Viair would probably be better though if it's going to get used too much without spending the big $
Delux2769
Lakewood, CO, USA
I have both the cheapest $9.99 Harbor Freight compressor and a VIAR 88P I got on Amazon for $46.
I've used the HF one about 20 times over the year I had it. Worked great, super cheap, super slow, needed to cool down between tires. It never failed me, yes the internal heat switch on and keep it off for several minutes. Always came back on when cooled down. Has a handy carry bag. Packs small. Plugs into 12V port in the rear trunk area or front seats for simple airing of front or rear tires.
The VIAR 88P can air up 3 tires to the HF 1 tire. Takes up more space. Runs cooler. Only runs off the battery clamps. Vehicle has to be running.
Granted, I'm much happier with the VIAR now... still keep the HF in my spare tire compartment as a spare or to pay it forward someday.
Pic shows HF freight on back tire and VIAR on front tire of my lifted '05 Forester on 30"s.
Sent using telepathically controlled dolphin fingers.
CHILL907
Peoria, AZ
geekyadam
Mead, CO, USA
Adam
Wright
Great info! I guess if they're lower powered, it's nice to have 2 rather than 1! ;)
Craig M
Haslet, Texas, USA
Craig
Mattson
Army
I also have the Viair 88P (since January) and am happy with it so far. Granted, I have only used it to air up twice, but had no issue getting all 4 tires from ~17 psi to ~35 psi in just a few minutes each (35/12.50/17).
ntgbrl
I was actually thinking about giving this HarborFreight one a try...
https://m.harborfreight.com/12volt-150-psi-compact-air-compressor-69285.html
It's $60 but with a 20% coupon it'd be about $50.
Don't do it. I got one as a gift several years back for airing up the tiny tires on my Miata race car, and the thing would overheat often when bringing the pressures from 25 to 35 psi. With the 31" tires on one of my Jeeps, it'll bring one tire from 20 to 45psi before having to stop and wait for it to cool down. Airing up all 4 31"s would take an hour or more with the cooldown times. On top of that, the switches would constantly burn out, so I had to repair it often.
I replaced the Harbor Freight compressor with a Viair 88p and have had no problems since. Ive aired up the 35" tires on one of my Jeeps from 20 to 35 psi several times, and it has performed well.
805RADO
Santa Ynez, CA, USA
Lost
Sasquatch
Thanks all for the help, I ended up going for something slightly more than $100. Vair 300p. Got good reviews and right about the amount I was willing to spend. Knock on wood I got a good one. It is nice that it is still small enough to fit under my back seat, barely.
805RADO
Santa Ynez, CA, USA
Lost
Sasquatch
Just ordered the Vair 88P from Amazon for $49.91
Sent from my SM-T560NU using OB Talk mobile app
I almost went for that but the valve on the 300p is the standard quick release one you see on big air compressors. I thought I might be able to attach some nicer hoses to it one day or figure out a small nail gun possibly? Idk
Reactions: Mike G
Mike G
San Jose, CA
I was thinking about the 300p but it was only rated up to a 31" tire and the 88p was rated up to a 33" tire. Which is odd since the 300p looks like a better built compressor. What size tires are you running on your rig?
Juggernaut
Chino Ca
Kenneth
Hart
100% guaranteed best investment for up to 33" tires, Viair 88P. $50! 15 lbs - 44 lbs in 3 minutes (265/75 16 = 31.5") with a 25 minute run time. I spent weeks comparing them all. I could not be happier.
Reactions: 805RADO
