Traveler II
Hey all, I've got an '89 Grand Wagoneer, and the engine is carbureted, but I've seen CARB approved kits for the AMC 360 to install Chevy 350 TBI kits. Is a TBI that much better than a stock carburetor?
Traveler II
Traveler II
Are you planning to travel through any big elevation changes ?A freshly rebuilt motorcraft 2bbl. It's been running just fine, but I've heard that TBI can net you some (5%) MPG gain.
Traveler II
That's one big advantage to fuel injection vs Carb
It is an advantage but personally I don't think it's as big as most think. I've been driving vehicles with carbs over 50 years and if the carb os set up right they work fine. I grew up in CO at 8000-9000' feet and carbs worked fine. In todays world are they as good as fuel injecton? Absolutely not. But we're talking vehicles here that usually are going slow and easing along looking at the scenery and enjoying the outdoors.Are you planning to travel through any big elevation changes ?
Traveler II
Any idea if an '89 Grand Waggy carb would have a barometric adjustment? I can't find any information either way.Two places EFI might be better, big elevation changes and driving off camber, like rock crawling but even in those 2 cases there are carbs which are designed to work well. My '78 F250 CrewCab was an old forestrytruck and had a carb which automatically adjusted for elevation changes, actually barometric pressure changes.
But if either of those affect your driving, I'd say EFI is a better solution.
Where I like a carb is low rpm luggiing. My TJ hates anything below 1000rpm but my '87 YJ would pull from 600rpm. 600rpm is a wonderful thing on ice or compact snow. I often started in second gear in the winter.
Traveler II
I would have to do more research about how to install it. Most likely for these bigger things, I would send it to a shop. I just don't have the space in my apartment to do a lot myself :/It is an advantage but personally I don't think it's as big as most think. I've been driving vehicles with carbs over 50 years and if the carb os set up right they work fine. I grew up in CO at 8000-9000' feet and carbs worked fine. In todays world are they as good as fuel injecton? Absolutely not. But we're talking vehicles here that usually are going slow and easing along looking at the scenery and enjoying the outdoors.
Sure injection is good, will get better mileage (lmao), be easier to start but from all I've read and seen it will run $1000-$1500 before you done and it's working well. I have a 73 Wagoneer and looked into it for mine but decided for as much as I plan on doing it I'll stick with the carb.
I don't remember if anyone asked how many mines you plan on driving every year in it. Are you able to put it on and tune it or will it got to a shop?
Traveler II
Better mileage would be one of my sticking points. The ~11-12 I get now hurts a lot.It is an advantage but personally I don't think it's as big as most think. I've been driving vehicles with carbs over 50 years and if the carb os set up right they work fine. I grew up in CO at 8000-9000' feet and carbs worked fine. In todays world are they as good as fuel injecton? Absolutely not. But we're talking vehicles here that usually are going slow and easing along looking at the scenery and enjoying the outdoors.
If you're lucky the "increase" will get you from 11-12 to 12-13. What gears and tires are you running?Better mileage would be one of my sticking points. The ~11-12 I get now hurts a lot.
I agree with Hemi!In my opinion, if it runs good and you're not getting crazy, that Motorcraft 2 brl is pretty bulletproof, just carry some extra fuel for long trips.
I'm thinking not. They were pretty rare and only sold in mountainous regions. Mostly on commercial vehicles.Any idea if an '89 Grand Waggy carb would have a barometric adjustment? I can't find any information either way.
Traveler II
AMC used 2 different 2 barrel carbs, the Motocraft 2100 and 2150. The difference is the 2150 had the anaroid bellows for altitude adjustment. It is simply a port on the back of the carb that is opened to let in extra air or closed depending on the air pressure on the bellows. Maybe this weekend I can snap a picture if you like. Easy to tell, if there is a blank port on the back of the carb, you have a 2100, if there is a cylindrical device attached and sticks out about an inch and a half, you have the 2150. Not sure if Chrysler carried this into the 80's, but AMC did on V8s headed to dealerships above 4000 ft elevation. If the carb works well, and no emissions testing issues, keep it. But.... the TBI will do much better with elevation changes, temperature changes, inclines, rough trails, and allow you to take a number of your smog devices off (for my 76 that includes removing EGR valve, air injection, and thermal air cleaner system). With emission parts hard to find and no longer made, I'm getting close to ditching my carb for the TBI simply because my EGR delay valve is off time and no longer available. It all depends on the smog guys mood if he lets it pass. You gotta love California... and it is hard to find any one with the old sniffer smog check system and the willingness to bother. Its all plug in the computer now and let the software do the work. The TBI will make the smog guys smile. I would not consider MPG in your decision, there is no meaningful change if your carb is working correctlyAny idea if an '89 Grand Waggy carb would have a barometric adjustment? I can't find any information either way.
