Built '91 Isuzu Amigo in Nashville, TN
Theo
Nashville
Built ATK 4zei1 engine with virtually everything replaced connected to it. New injectors fuel lines etc. Huge oil cooler, new radiator and heater core. Rebuilt MUA trans with Terra Low gears in tcase. ARB rear locker, new front axleshafts. Newer control arm bushings, steering gearbox, power steering pump and all tie rids and joints new. All wear items on vehicle have been replaced last 5 years. This can hit some pretty tough trails and cruise all day at 75mph. About 5k on bfg at's, new front calipers and rotors with newer rears. Can answer any questions and have documents for virtually all parts. No rust, some dents and scratches from trail use. No AC but good heat. Baja designs lights and high idle switch. Crack in windshield. Top is good and no leaks from it or sunroof. Thanks, Theo
Theo
Nashville
Forgot a bunch of stuff but replaced flywheel, clutch, slave and master cylinder. Also has 3500 watt inverter in cab. Tons of extras including engine, knuckles hubs bearings, throttle body, etc..New projects and I need the garage space and don't hit the trails as much as we used too. Pretty firm at $5500 but will entertain trades. If interested I can get any pictures you need.
