Any thought...flexseal for fluid leaks?
Rubyredfozzy
Benefactor
3,771
Fort Mitchell, AL, USA
Aaron
Welch
has anyone tried to use that flex seal for any type of flip leaks. I know on the commercials they can seal up water leaks but how does it hold up to chemicals in vehicle fluids. for example a radiator hose leak or a hole in a gas tank. I have some serious sticky pads that are used to seal wounds to peoples chest in serious injuries that I think would work in a pinch as well.
any thoughts?
Homeguy
Calgary, AB
I have a buddy that sprayed his evap canister on his JKU because it was cracked and throwing a code. After he put 3 coats of it on the entire canister he never got another code. Since I’ve sprayed mine for insurance. Stuff works great
Sent from my iPhone using Tapatalk Pro
Reactions: Rubyredfozzy
HEYElliott
Markham, Ontario, Canada
I learned from 4wd action on youtube that bar soap is a quick hack for various leaks like oil and fuel. In an ideal situation I imagine flex seal would be killer. I like the preventative thought of it. Although i might just use some form of bedliner for the strength aspect.
Rubyredfozzy
Benefactor
3,771
Aaron
Welch
The bar soap is clever. And I'm sure if you are out on a trip you may just have some in a hygiene kit.
Sent from my SAMSUNG-SM-G891A using OB Talk mobile app
Rubyredfozzy
Benefactor
3,771
Aaron
Welch
