Educator I
12989
You put this in the buy sell trade group.Which 12 gauge ammo is best for home defense?
Darned good advice! Training and knowing your weapon(s) is paramount!Well if a shotgun is all you have and don't have the funds to buy an alternative firearm, then I would agree @Downs and running at least a #4 buckshot. Average target distance in a home is going to be less than 10 yds. The pattern at that range is going to be pretty tight even with an 18" barrel.
And Yes, a shotgun will do the job, However, you are typically limited to a max of 8 rds with a massive recoil which makes a follow up shot more challenging and a reload slow.
Honestly, In todays climate, I would highly recommend at a minimum a higher capacity 9mm or 40 cal for quick access to get you to an AR pistol (not an SBR) to put the odds in your favor.
But more than anything, TRAIN, know your weapon well, and practice in your home (unloaded, dryfire drills) and pay attention to where your safe shooting lanes are, especially if you don't live alone!!
Trail Blazer III
20527
Trail Blazer III
20527
Curious, why would you rack the slugs out?I put the 2 slugs first, so I can rack them out.
I wouldn't alternate them.
The sound alone will cause them to run off.Curious, why would you rack the slugs out?
Or start unloading in the direction of the sound…The sound alone will cause them to run off.Curious, why would you rack the slugs out?
Trail Blazer III
28559
From my time in law enforcement and the military I learned there are 3 types of home invasion.Or start unloading in the direction of the sound…The sound alone will cause them to run off.Curious, why would you rack the slugs out?
First shot is your most accurate shot… fallow up with a round of buck shot in case you missed with the first. Then final tap with the last slug.Curious, why would you rack the slugs out?
Agree. Shotgun in general is a lot of collateral damage.Ever see a slug bounce around a forest?
Too much collateral damage from a miss. The slugs are in there for barriers or range. 00 is my go to, the slugs are optional.
