'78 Dodge PTO Hydraulic pump
Buzzard13
Mesquite, NV, USA
Austin
Tressel
Looking for information and leads on a PTO for the NP203. I want to get an older hydraulic winch. To me the hydraulic would be better than drive shaft and more versatile.
Thanks.
US Northwest Region Director
Benefactor
Pathfinder II
4,861
La Grande, Oregon, USA
Rose
KJ7MFV
Thanks.
I’m running a Mile-Marker 18000 off of a purpose built Saginaw power steering pump... it cost me $25 at the junk yard and about 2 hours to mod it.
as for the pto, there is a lot of variables to go this route... a new pto costs about $500 without the adapters necessary. The Chelsea 442 is the only PTO that will work with the NP203, but as you look at the page there is literally 100s of options.
Reactions: Buzzard13
Buzzard13
Mesquite, NV, USA
Austin
Tressel
If possible I would get something original and used.
I personally don't like the idea of running off my steering pump.
How likely is it to find an old pto on ebay or the junk yards?
Would it be the Chelsea 442 or something else?
I feel a pto is built for accessories and is more versatile that running off the steering pump.
Is Mile Marker going to be the most common hydro winch?
Is it the best?
So many questions.
Thanks for all of the advise.
Benefactor
Pathfinder II
4,861
Rose
KJ7MFV
Is it the best?
So many questions.
Mile-Marker is the leader in Hydraulic winches... and they are designed to work off of stock power steering units and even have installation kits for most applications... I’ll fallow you in DM
Desert Runner
Traveler II
3,335
Southern Nevada
Jerold
F.
/GMRS=WREA307
Is it the best?
So many questions.
I believe, but don't quote me, as it has been many years......, but on a side note,...... the Allison transmission offered by GM in the Silverado, was able to use a PTO system. Some kind of design change was initiated after 2003 ? which made it necessary to having the case opened and parts installed. Before that it was 'capped-off'' , but had the internals that allowed a PTO system to be used. I remember kit's being available to tie in the system. Transmission instead of P/S pumps, not sure about which would be better, but something breaking in theP/S would not neccessarily sideline your vehicle in case of breakage.
Just thought I would throw that out there, since it was PTO related :blush:
Benefactor
Pathfinder II
4,861
Rose
KJ7MFV
This was true in all NP203 Transfer cases... the provisions are there to add a PTO with the proper kit... it’s knowing which kit to buy to give the gear ratio needed for the hydraulic pump...
Modding a Saginaw Power Steering Pump and using it as a secondary pump is actually very simple... to mod the pump you just need to drill a hole and add two washers. Making the mounting bracket is a little harder but doable... I used the smog pump location and moded the bracket to accept the Saginaw pump.
Boostpowered
Traveler II
4,449
Hunt county, TX, USA
Davis
I think most of the old pto's your thinking of are nearly as rare as hens teeth. You might find some on old plow trucks but they will likely be rusted up junk by now. Craigslist search old snowbelt areas or junkyards.
If its a gm you'll be looking for a Muncie TG6S-N7018-C2BT muncies is easier to rebuild and re gear usually cheaper than chelseas.
