Hi all! First post here on OB...loving the community and the resources!
So I've got a 2001 4Runner 4x4, about 270k miles, that recently started a squeal/squeak from the rear end while in reverse. Quick look around some other forums leads me to believe that the rear u-joint is going bad, as this is apparently common with the 3rd gens. I talked to the only reputable driveline shop in my area, and they said they don't replace the u-joints only for the 4WD models, and would only replace the driveshaft as a whole unit w/ new components. So instead of a $50 u-joint replacement part, it's ~$700 for the shaft and install. So here's my question...
Money is kinda tight right now, even with that nice stimulus check that came through. When shelter-at-home orders are lifted, we plan on taking a 2-week long road trip around California parks - Yosemite, Redwoods, etc. - and doing some low-risk off-roading & camping (I have two young kids, so I'm not planning on doing any crazy rock crawling or stuff that would stress the rig too terribly much). In terms of vehicle functionality, how likely is it that my u-joint completely fails and I'm left stranded? Is it one of those things that will make an annoying noise but continue to function for a long time, or am I looking at needing to replace it before taking an extended trip?
Any advice would be much appreciated. This rig has been my introduction to more advanced car mechanics and maintenance; my knowledge before this was pretty much changing oil and tires
Obviously the long-term solution is to just replace the driveshaft, but I'm trying to conserve funds for other things right now. Thanks!
