This is the ongoing build of my 2016 Laramie Power Wagon. I recently have gained a huge love of the overland lifestyle and it has definitely given me a new direction in which I will build my truck so the wife and I can enjoy more time away from the daily grind.
In this picture the truck was only a few days old and is totally stock other than the wheels and tires. This was the first time the truck was taken off pavement. Since then the truck has been through numerous upgrades and modifications to suit my needs, wants and expectations. This is my daily driver, tow rig, camping rig, and family trip rig. My build is geared towards a vehicle that can go wherever I want to go on or off pavement yet not be so purpose built that it limits where I can go with it. This truck has been across a good portion of the western US since I bought it in late 2015. To date the following modifications have been made:
2016 RAM 2500 Laramie Power Wagon Overland Build
Current Modifications:
Powertrain
- 90mm BBK Throttle body
- Custom airbox to TB intake tube
- Muffler delete (OEM Resonator in place)
- Diablo Trinity Tuner with modified 91 octane tune
- Unlocked ECM
- 4.88 Nitro gears in front differential, 4.88 Yukon gears in rear diff
- OEM locking differentials
- OEM Electronic disconnect sway bar
- Yukon free-spin hub conversion
Suspension/Tires
- Thuren Coil springs front
- Thuren Coils springs rear
- Thuren Rear track bar
- Thuren Boogie Bump bump stops
- Thuren XHD sway links
- DOR rear control arms
- Bilstein 5160 Series Remote Res front shocks
- Bilstein 5100 Series rear shocks
- Thuren/KING 2.5" stage 5 tuned shocks
- Thuren/KING Steering Damper
- Thuren front axle truss
- Carli Track Bar
- 37x13.5x17 Toyo Open Country MT tires
- 17x9" American Outlaw Wheels
Interior
- Marine Style 8 switch accessory panel w/12v and USB ports and digital voltage gauge mounted in center stack
- GoPro Mount
- Tinted windows
- Column mounted digital/analog air pressure gauge
- Emergency flare/triangle kit
- 3 First-aid kits (light duty medical to first responder)
Exterior
- Addictive Desert Designs HoneyBadger rear bumper with lockable storage and recovery points
- MOPAR Tri-fold hard bed cover
- Shorty Antenna
- Peel coated grill shell
- Anti glare vinyl wrap on hood
- Deleted lower front bumper valance for approach angle
- Pocket style flares to cover larger tires
Lighting
- Customized factory headlight housings with multi-colored selectable LED backilighting
- Rigid Industries Grille with 30" RDS series light bar
- Rigid Industries 20" E-series Combo Light bar
- 4x Rigid Industries Radiance pods mounted on ZRoadZ hood hinge mounts
- 2x Rigid D2 flood pods mounted in rear bumper
- LEDMircy Rock lights. 12 pods mounted under truck with one additional pod mounted over the winch to backlight the spool in low light usage
Armor:
- OEM Power Wagon Skid Plate package (T-Case/Fuel Tank)
- Carli Front differential Guard
- AEV Nodular cast rear diff cover
- White Knuckle wheel to wheel sliders
- Dethloff Mfg Engine/trans skid plate
Recovery:
- OEM installed Warn winch w/ factory wired control
- Warn wireless remote
- Hard-wired winch controls
- Factor55 Receiver Hitch D-Ring
- Factor55 Prolink winch hook
- Various selection of D-ring shackles
- 2x Snatch blocks
- 4x 20' recovery straps
- 2x tree savers
- 20' chain
- 48" Highlift Jack
- Viair 150psi 100% duty cycle compressor with dual 2.5 gallon storage tanks
- 2 separate self coiling 50' air hoses with quick couple for running air tools or reaching longer distance from vehicle
- 2 dedicated regulated tire air up hose allowing for all 4 tires to be aired up simultaneously.
- Smittybuilt Trail shovel/trail axe
- Full-size trail shovel
- Double headed axe
- 2x Tire repair kit
- ARB Deflator
Comms:
- Midland GXT1000P handheld radios
- Wilson Cell booster
Future mods include;
Thuren high clearance front bumper
Thuren front track bar
Artec Industries rear axle truss
Custom Roof and Bed racks with area lighting
RTT rack mounted above bed
Rack mounted Awning
2nd compressor with 2 additional 2.5 gallon tanks
CB and HAM radio
Front camera
Internal Beadlocks
Rear winch
On board water storage with heating capability and pump
Solar charging with additional battery storage
12V fridge/freezer
Dyna Trac or Carli Ball joints
Slide out bed tray with built in outdoor kitchen
2nd fullsize spare
Snorkel intake
and who knows what else I will find I need/want along the way.
Below are more current pics of the truck in its current state.
Powertrain
- Unlocked ECM
Suspension/Tires
- Carli Track Bar
Interior
- GoPro Mount
- Tinted windows
Exterior
- Shorty Antenna
Lighting
Armor:
Recovery:
- 2x Snatch blocks
- 2x tree savers
- 20' chain
- 48" Highlift Jack
- Double headed axe
- ARB Deflator
Comms:
Rack mounted Awning
CB and HAM radio
Front camera
Internal Beadlocks
Rear winch
12V fridge/freezer
2nd fullsize spare
Snorkel intake
