2004 4runner built 4.7 v8 35's in SE Idaho
Tmalm3013
Southern Idaho
  • Description: 4.7 V8 4x4. 267K miles but runs like a top. Timing belt recently replaced, as well as water pump and coolant flush so it should be good to go for another 90,000 miles until it needs anything. It spent most of its life in Arizona so there is almost no rust, the frame is in great shape as well as everything else on it structurally. There are some scratches and minor dents but it cleans up great and has never bothered me. Does have a subwoofer installed with a Bluetooth radio, willing to let those go with the car.
  • Rig is ready for action and has been an awesome overlanding and exploration vehicle, it has never let me down and I truly think it has years and years of life left in it. Only selling it because I want to get into an 80 series cruiser. PM me for more info.
    Upgrades:
    Rear brake lines extended - July 2017
    Bilstein 6112 Coil overs with ebiach coils and kyb strut tops - July 2017
    Fox 2.0 shocks rear - July 2017
    Dobinson's long travel medium rate coils rear - July 2017
    NWTI bumper - July 2017
    Trail Gear DOM rock sliders - November 2017
    Tuff Stuff 12,000 LB winch w/ steel cable - Feb 2018
    5% window tint
    315/70r17 Stt Pro (4) tires from discount tire 1-23-19
    4 new rims -6 offset 8in wide 1-23-19
    Rear Plate steel bumper – Custom
    Rear Bump Stop Extension (1.5")
    Maintenance
    Passenger side wheel bearing - April 2017
    Inner and outer tie rods w/ OEM boots - July 2017
    Drivers side CV axle - Feb 2018
    Drivers side LCA w/ LBJ and bushings March 2018
    Passenger side LCA with new LBJ, Bushings, and SPC Cam bolts Nov. 29th 2018
    Power steering pump - January 2018
    Reman 2.0 Kw starter - May 2018
    New Battery May 2018
    Intake and throttle body gaskets - May 2018
    Coolant flush when replacing water pump and T belt
    Timing Belt w/ water pump Done Oct 2018
    Body Mount Chop with 35's
    Front inner fender clearance, fender and flare trimmed for 35's
    Differential fluid (front and rear) and t-case fluid changed in Feb. 2019
  • Price 13,000 OBO
  • Shipping: Willing to meet up with anyone in the area, can arrange to meet up/get you here if you are farther away and serous about it.
