hello there overland bound people,
I've got lately a 1999 Toyota land cruiser and got it first to a local specialist garage to get it fully inspected,
it's at 208k miles right now and seems like the *timing belt has never been replaced.
so I have ordered the Aisin timing belt kit, but I know a few items are missing like the thermostat and 2 other parts.
plus I wanted to ask if already we will be reaching "deep" what else would you recommend to replace.
oh yes and I do need to replace the **T of the heater.
would you recommend OEM or the metal version aftermarket would be better?
what about the ***rack and pinion I would love to get any recommendations if the re-build ones are any good? is it better to a brand new one OEM ? or is there something better ? or the rebuilt kit for it is good and not too complicated for a mechanic to re-build it with that kit?
sorry to be over the place sometimes the none official ADHD is kicking in so... ill make some order.
*timing belt kit :
is this the full list of ALL the items that need to be replaced?
1X Water Pump
1XTiming Belt
1XIdler Roller
1XTensioner Roller
1XFront Crankshaft Seal
2XFront Camshaft Seals
1XThermostat
1xHydraulic Tensioner
1XSerpentine Drive Belt
**T of the heater: is the metallic version the T connector or the metallic/aluminum version?
***Rack and pinion:
new OEM
rebuild OEM
DIY rebuild kit
aftermarket?
*timing belt kit :
1X Water Pump
1XTiming Belt
1XIdler Roller
1XTensioner Roller
1XThermostat
***Rack and pinion:
new OEM
rebuild OEM
DIY rebuild kit
aftermarket?
